Coils keep going bad
Old Aug 11, 2008 | 07:49 PM
dei227's Avatar
2001 Camaro with the V6. I have replaced 4 coils in the last 3 months and they seem to be radom as which one goes out.What could be the culprit of this?
Old Aug 11, 2008 | 11:12 PM
95camaroinok's Avatar
try getting your money back and/or try different brands. check your grounds, and check your ignition control module. If you can find a cheap control module in the salvage yard, try swapping that out first. When the coils go bad, have you tried just swapping it with another one on the car to see if the problem follows the coil, or if it stays in the same position? If you cant track it down, try finding cheap salvage yard parts to test it before spending $$$$ on new parts. You can always buy a new one after you find the problem and then you'll have a cheap spare.
Old Aug 12, 2008 | 04:36 PM
dei227's Avatar
When you say check the grounds......Where are these grounds ?
Thanks for your help .
TitoPR221
May 26, 2015 12:20 AM
Noenav
Apr 30, 2015 01:06 PM
ad356
Apr 11, 2015 11:12 PM
captcorvette
Mar 7, 2015 12:37 PM
maybe2fast
Feb 5, 2015 05:14 AM
