Break Light/Signal Electrical Problems
Old Apr 20, 2007 | 03:32 PM
Props's Avatar
Im hoping someone here can help me so I dont have to get my car towed to a shop for somthing simple...
(94 Camaro)
My right back side break light blubs were out, so I changed them, and they worked fine, as did the signal lights. I noticed the indicator bulb was black and obviously not working and had kind of melted the plastic casing it sit in to the bulb. After prying the bulb out, I replaced that one to, which then worked, BUT now after i touched my breaks NONE of the back lights go on save the trunk light, and on top of that, the back signal lights no longer work as well. The front lights come on, and stay on indicating a problem (duh).
I checked the fuses on the drivers side panel and everything seemed to be ok.
What other problems could have happened?
Thanks to anyone for some help,
Mark
Old Apr 20, 2007 | 09:50 PM
chevynutman's Avatar
if your front parking lights come on then stay on after hitting brake there is probably a harness short somewhere if that is not what is happening i don't understand what is going on
Old Apr 21, 2007 | 03:18 PM
Props's Avatar
I meant to say the front signal lights still work, but dont blink anymore. And the break lights only work on the trunk light.
I was thinking that the back break lights and back signal lights are on the same circuit?
liamcg97
Nov 25, 2019 05:55 PM
Victor Lamb
Aug 26, 2017 02:52 PM
cmyname1
Feb 19, 2015 08:38 PM
97z28k&N
Jan 9, 2015 04:58 AM
