99 firebird V-6 issues
Old Apr 16, 2012 | 02:38 PM
jcl69cam's Avatar
My daughters 99 firebird has a problem while driving, the oil pressure and amp gauges bounce around and the car seems to be missing. No SES is showing. Tried higher octane fuels, and a new fuel filter. The car stubbles worse up hills. Any help would be appreciated.
Old Apr 16, 2012 | 03:57 PM
Dave89IROC's Avatar
Is it actually missing, those are known for coils dying
Sent from my PC36100 using Tapatalk 2
Old Apr 17, 2012 | 08:12 AM
jcl69cam's Avatar
Re: 99 firebird V-6 issues
Yea, its missing, but there isn't any ses lights. And it seems to run worse up hills.
Old Apr 19, 2012 | 06:45 PM
camarogeek's Avatar
I would do a scan to check for codes. The check engine bulb could be burned out. Is it really missing with bad vibrations and all or just having a general loss of power? I had a clogged cat that resulted in power loss that was only really noticeable when you got on it or went up hills. I also had my share of misfire issues due to wires that had melted/cracked and were shorting out.
Old Apr 22, 2012 | 09:39 AM
jcl69cam's Avatar
The ses light is out, I scanned it. Showed a misfire on the #6 cylinder. It was a bad coil pack. Thanks.
timmy39120
May 8, 2015 11:41 AM
cmdeshon
Dec 12, 2014 10:51 PM
Hoodshaker
Aug 27, 2002 02:32 PM
CamaroRSguy
10
Aug 6, 2002 04:26 PM
CamaroRSguy
12
Jul 8, 2002 09:39 PM
