98 3.8L Fuel pressure
Old Oct 31, 2007 | 02:26 PM
sma's Avatar
sma
I have a 98 Firebird 3.8L. I checked fuel pressure key on not running and it is 44 psi. With engine running and vacuum line disconnected it is 52 psi. Is this adequate? I have a P0301 ses code and replaced plugs wires coil pack icm and switched injector. The plug from cyl 1 was clean.
Old Oct 31, 2007 | 03:54 PM
2001NBMZ28's Avatar
Looked it up in my '01 helms and for the 3.8, commanding the fuel pump on with a scan tool, ignition on -car off should be 48-54 psi. Also says to command it on a few times to get the highest reading. Doesn't sound like a fuel pump issue, something else is going on.
Old Nov 2, 2007 | 09:23 AM
sma's Avatar
sma
My Haynes manual also says 48 - 55 psi key on not running. I am only getting 44psi. Engine running and vacuum line disconnected it is 52 psi. If pressure is adequate could flow rate be inadequate?
CaptainObviousI
29
Apr 29, 2021 10:35 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
Jul 4, 2005 05:00 PM
