95 3.4l V6 Raditor Flush how to ?
i want to change my raditor fluid in my other 1995 camaro v6 3.4l , but i cant find the bleeder screws so , i dont want to do it , unless i can find the bleeders screws so i can get all the air out of the system ? . where are they , and does anyone have a guide for flushing the raditor online ?
Also , how much total coolant does this setup hold when i refill it up ?
Thank you
Thank you
Re: 95 3.4l V6 Raditor Flush how to ?
The usual bleeding process on a car for coolant systems, is to leave the rad. cap off and let the car run for about 15-20 mins and it will "burp". It will over flow a couple times then the t-stat will open up and suck the coolant in then yous low refill it and top it off THEN close the cap and then turn the car off or you will get a huge mess if you turn the car off with out putting the cap on first
