94 camaro 3.4 v6 problems
Old Jul 21, 2010 | 05:47 PM
mattdock08's Avatar
ok i have a few problems. first off the car is hard to start on the first start. cranks over and eventually fires up but sometimes i have to give it some gas for it to stay running or it'll die. once started it'll start right up easy. after its started the rpms bob back and fourth between around 500 rpms and 800 rpms and when its around 500 rpms it vibrates and sounds like its about to die tho it dont. everytime i start it its getting worse and running worse. the car has about 200k miles on it. one last thing is once the car is running when i give it some gas it hesitates really bad for a few seconds like its not getting any fuel and eventually will go tho its not very drivable...any ideas?
Old Jul 21, 2010 | 05:48 PM
mattdock08's Avatar
new update now the rpms are dropping enough that the car does die and its as hard to start as ever will idle after awhile but still not gettin gas or something
Old Jul 22, 2010 | 07:46 AM
vincerosas818's Avatar
sounds like a pretty heavy repair job if you have all that going on..if you cant fix it, Sell it for parts and get another dude. lol
Old Jul 24, 2010 | 03:04 PM
spontaneouslife's Avatar
my '94 camaro is doing the exact same thing =(
Old Jul 24, 2010 | 10:51 PM
95camaroinok's Avatar
Check the fuel pressure, ignition module and catalytic converter.
Old Jul 25, 2010 | 07:35 PM
ZTWNTY8's Avatar
The last part about how u said it hesitates to get fuel check ut throttle position sensor , about the hard start clean out the m.a.s. With electrical parts cleaner not brake cleaner or carb.cleaner and clean out ur iac motor .
Old Jul 26, 2010 | 05:41 PM
mattdock08's Avatar
k thx once i try ill post an update
Red Hawk 94
Mar 18, 2019 04:03 PM
SpeedJunkee
Jan 27, 2015 10:02 PM
bernie1951
Dec 10, 2014 10:03 AM
Eric H
Aug 10, 2002 06:39 AM
Chrisdude
Jul 24, 2002 02:25 PM
