1994 v6 3.4 camaro problem
Old Aug 11, 2010 | 04:38 AM
Ccamaro904's Avatar
Unhappy 1994 v6 3.4 camaro problem
I have a 1994 v6 3.4l camaro and when ever I'm in drive at take off and I slam the gas it vibarates and goes no where all spark plugs are right and new and when I'm driving if I'm steady on gas it drives smooth but when I punch it it just vibarates and goes nowhere I'm lost on what it could be pls help ..
Old Aug 11, 2010 | 11:15 AM
BC2002SS's Avatar
I would start by checking the fuel pressure, check it under load also. Run a line from under the hood so you can see the gauge when driving. when was the fuel filter last changed?
Old Aug 11, 2010 | 12:31 PM
Ccamaro904's Avatar
I changed it and got a full tune up bought month in a half ago my friends keep saying it's prob a sensor but idk what sensor would do that or if any
Old Aug 11, 2010 | 02:05 PM
BC2002SS's Avatar
take it to a parts store and have it scanned for codes.
Old Aug 11, 2010 | 02:58 PM
Ccamaro904's Avatar
I have clue what place dose almost none do here in Jacksonville or I can't find one that dose OBD1
Old Aug 11, 2010 | 03:22 PM
EineKatze's Avatar
Paperclip
Run a paper clip between your terminals on your computer. Turn the ignition to On and the Check Engine Light will flash any trouble code to you in moris code. Google a list of trouble codes for the 94 and match your blinks. Hope this helps.
Old Aug 12, 2010 | 11:55 PM
Ccamaro904's Avatar
Dose that work on the 1994 3.4 v6s because some say it don't and if dose way 2 prongs do u put the paper clip in ?
Old Aug 26, 2010 | 04:15 PM
EineKatze's Avatar
I own a 94 3.4 with the T-5 in it. Don't know what you run, but the way you say stomping the gas makes me think yours is auto. I know that this works as I have done it myself quite a few times. I believe there are only two terminals that can be connected to anyway. There are multiple connector "ports" if you will, but only two have prongs to connect to. I could be wrong, I'll attempt to check my car when I get a free moment and post a picture if possible. I actually just joined to answer your post, so i don't know how the image system works. I have been a troll for years
Old Jan 1, 2011 | 07:51 AM
airbud7's Avatar
Re: 1994 v6 3.4 camaro problem
I had a cracked spark plug that did that...it would jump fire under load...
Red Hawk 94
Mar 18, 2019 04:03 PM
Noenav
Mar 1, 2019 07:38 AM
SpeedJunkee
Jan 27, 2015 10:02 PM
Scottylt1
Jan 8, 2015 02:48 PM
1LEThumper
Jul 14, 2003 12:45 PM
