Track Kill Stories Race Track Victories, 1/4 Mile Times, Dyno Numbers - DRIVE RESPONSIBLY
LS1 vs LT4
Old Jul 14, 2005 | 09:01 PM
  #16
GPZ28's Avatar
Re: LS1 vs LT4
89 corvette was the first 6 speed. The 4+3 is a four speed with an overdrive bolted to the back of it.
The 96 vette isnt as light as some of you guys might think. I dont know the exact weight but its around 3400lbs. All 96 lt4's are 6 speeds and lt1's are all auto's
It will be close, as the lt4 is underrated as well. I still say that the ls1 will prevail............
Old Jul 14, 2005 | 09:07 PM
  #17
robb4964's Avatar
Re: LS1 vs LT4
Originally Posted by Shackleford
Actually, the LT4 makes a little more power than the LS1.
I disagree.LT4's make 330. Never saw an LS1 dyno that didnt prove to make more then 330.
Old Jul 14, 2005 | 09:14 PM
  #18
00Z28SS's Avatar
Re: LS1 vs LT4
Especially a modded LS1 vs. a stock LT4. It's not going to be close. With the lt's and 4:10 alone you will burn him.
Old Jul 14, 2005 | 10:53 PM
  #19
mhhodges76's Avatar
Re: LS1 vs LT4
Originally Posted by SnakeSkinner28
I think he meant that it was only possible to get the LT4 Vette in a 6sp, not the fact he was questioning whether or not it was a 6sp. Vettes do come standard autos, so he was sayin LT4s were only 6s.
Yes that is exactly what I meant. Thanks for clearing it up for him.
Originally Posted by mustangmuncher
I think in 1996 (year of the LT4 vettes) that all manual vettes had the LT4? That might be a myth. And if you can drive, you should pull it out no problem, but only if that LT4 is stock. If the owner did bolt-ons and a hotcam swap, then he would be right around 375 hp give or take a few.
Correct me if I'm wrong...but isn't the hotcam from the LT4 originally? It is called an LT4 hotcam. So the hotcam is the stock cam for the LT4 motor. I also believe they have a different intake manifold.
Old Jul 15, 2005 | 12:23 AM
  #20
Ray86IROC's Avatar
Re: LS1 vs LT4
No, there is a standard LT4 cam that came in all the factory cars, it's barely any different at all from the LT1 cam actually. Much like there is a LS1 Hotcam that is a performance part over the standard LS1 cams...
Old Jul 15, 2005 | 01:18 AM
  #21
ShawnLT4Z's Avatar
Re: LS1 vs LT4
i have a lt4 conversion package on my camaro (the 425 hp kit) i also have all the supporting mods like cai, exhuast, etc.
i raced a 2000 ss auto with hooker long tubes, ORY, lid, free ram air, granatelli mass air, smooth air bellows, and throttle body.
at the time i had a 2800 stalled auto, from a stop i would murder him. from a roll it was pretty even.
since the vette is stock, i think the ls1 will end up in front.... but only barely
Old Jul 15, 2005 | 02:25 AM
  #22
mhhodges76's Avatar
Re: LS1 vs LT4
That is a very confusing statement. Are you saying that lt4's make 330hp at the wheels? Also, you have never seen an LS1 dyno less than 330hp on a dyno?
Old Jul 15, 2005 | 02:49 AM
  #23
Ray86IROC's Avatar
Re: LS1 vs LT4
The stock LT4 vettes seem to dyno right at the same 300ish rwhp level as most stock LS1s from what I've read, which would peg the LT4 as pretty underrated.
http://www.grandsportregistry.com/dyno.htm has several stock LT4 dyno numbers, and plenty with mods.
Old Jul 15, 2005 | 07:02 AM
  #24
Antz97ZNJ's Avatar
Re: LS1 vs LT4
No myth thats fact
Old Jul 15, 2005 | 08:17 AM
  #25
robb4964's Avatar
Re: LS1 vs LT4
No. That would be rediculous. Im talking about crank HP.
Old Jul 15, 2005 | 08:19 AM
  #26
robb4964's Avatar
Re: LS1 vs LT4
You should take an LS1 with those mods compared to yours.
Old Jul 15, 2005 | 08:55 AM
  #27
mhhodges76's Avatar
Re: LS1 vs LT4
Dyno numbers should reflect RWHP and RWT. Crank HP is often inflated and meaningless. Besides, the early LS1's where rated at 305hp which is below 330 hp Correct? I'm not trying to be an ***, just calling them like I see them.
Old Jul 15, 2005 | 09:51 AM
  #28
yellavette's Avatar
Re: LS1 vs LT4
My brother's stock LT4 Vette made 308 rwhp and ran low 13's@107-108, so it's pretty comparable to the LS1.
Jason
Old Jul 15, 2005 | 11:28 PM
  #29
GPZ28's Avatar
Re: LS1 vs LT4
Correct, the lt4 is underrated also and really makes 350-360hp
Old Jul 16, 2005 | 08:56 AM
  #30
Bersaglieri's Avatar
Re: LS1 vs LT4
If its for money I'd watch and make sure he's actually stock. Most Vette guys I have seen rarely do much racing, but one reason to start would be having trick up their sleeve.
Can you confirm that its bone stock and does he know your modded?
-Dustin-
