Beat a built 3rd gen
A friend of mine has a 84 Z28 with the following mods (from his sig on thirdgen.org):
"I have worked over pro top lines, Edelbrock rpm air gap intake, demon 750 ts carb, Headman headers true duals v force muffler , 350 bored 40 over, Flat top pistons, 10 to 1 compression, comp cam xe274-h10, perform electric water pump, dual electric fans, aluminum power steering pump
fiberglass big block hood removed entire hvac system, removed radio-speakers, removed carpet padding, removed cruse system, and removed most unneeded wiring.
700r4, 2300 stall, Transgo shift kit, Posi rear end, 343 gears"
My car is in my sig.
Anyways we go to the highway, 3 honks from 10mph, I beat him by a car to about 120. We did this twice, both with the same results. I had about 200lbs more passenger weight than he did.
I bet you have got no idea how much power a LS1 WS6 makes do you?? The WS6 (I believe) has 345 hp and the 350 TPI makes 240 so you've got 105 hp to make up...Considering the WS6 and SS Camaro's were low 13s to extreme high 12s stock, That 3rd Gen has a HELL of a lot to catching up to do, even if it's built
Ok then. Congrats.
Nope no idea. I've been living under a rock
Ok I am gonna put this real simple.
A 155hp 305, combined with a cam, full bolt ons and the stock head ported/5-angle'd/shaved, will produce (depending on a lot of things, of course) anywhere from 320-360hp.
A TWO HUNDRED and fourty five hp TPI, combined with a cam and full bolt-ons? Well ****.. the possiblities are endless. Check out the third gen section. TONS of bolt-on L98's producing 380-420+hp. Combine that with a car thats much lighter than a fourth gen and you've got an LS1 killer.
Wow. What a goofball.
Ok I am gonna put this real simple. A 155hp 305, combined with a cam, full bolt ons and the stock head ported/5-angle'd/shaved, will produce (depending on a lot of things, of course) anywhere from 320-360hp.
here
http://web.camaross.com/forums/showthread.php?t=516911
What now.
That is a hot zone, and you criticize it? I bet the closest you have been to a hot zone was on the 4th of July, you once again, prove how much of a joke you are. America has left most of Afghanistan to the army......they where board because they wanted to be where most of the Marines are....Iraq. Are you gay or just a dumb broad? I got it, some overweight burnout that lives alone and hits on the drive through girl......too bad you sold that stellar 85' huh? You are a jackass!
BTW, I don't want to show you a video, I want to show you about me.
BTW, I don't want to show you a video, I want to show you about me.So since you are making a fool out of yourself and you are running out of things to say, I am now gay. Or a dumb broad. One or the other. Maybe both. VERY typical jarhead behavior; uneducated, rediculous things being spewn out of your too-large a head.
But ya I'm over weight, I'm not gonna lie. And I hit on ALL the drive thru girls. Because I'm not getting married in under two months.
Dont make TOO much fun of me
http://viewmorepics.myspace.com/inde...imageID=967165
Stroke me Jarhead. I live at 66 Main street in Depew NY. That's zip code 14043 incase you need that info for your plane ticket. Enjoy the ride.
And btw.. "i want to show you about me".. i haven't heard that phrase since some gay kid in HS named RJ tried inviting me to the bathroom after school.
