wheelhopping issues
Old Oct 30, 2006 | 05:57 PM
30th6's Avatar
wheelhopping issues
ok i just put a moser 9in with 35 spline axels detroit locker and 4:11's.i also put a umi tunnelbrace adjustable torque arm with my pinion angle set to -2 degrees.now my car is wheelhopping ive tried changing tires, airpressure and ive tryed taking my rear swaybar off and that didnt help either so i put it back on.what would yall suggest to help with this? thanks joe
Old Oct 30, 2006 | 07:46 PM
OBE1 95Z28's Avatar
Double check that you set the pinion angle correctly, it's not uncommon for folks to set it up wrong. -2 degree pinion angle should have the driveshaft and differential pinion yoke pointing slightly down like a "V".
Old Oct 31, 2006 | 04:00 PM
30th6's Avatar
Im Positive I Got The Pinion Angle Right Anything Else I Should Look For?
Old Oct 31, 2006 | 04:10 PM
mdacton's Avatar
i got the same rear....i never had that problem, but i did install some control arm relocation brackets from spohn. they have them for the moser rear and they fit great, they are weld in brackets.
my friend had this problem and the brackets took care of it
Old Nov 1, 2006 | 07:24 PM
Bayer-Z28's Avatar
Why take the rear SB off?? I allways thought the front one could be taken off for strip and weight reduction... But not the rear.. A thicker SB would actually help wheel hop, along w/ a straighter launch..
If you're car is lowered I'd strongly advise the LCA RLB'S. THe LCA's should be parallel w/ the ground or pointed down slightly (from the frame to the rear)..I have almost no WH w/ my RLB's.... Stiffer shox, would help too.
Old Nov 3, 2006 | 07:52 AM
30th6's Avatar
my car hasnt been lowered what cheap shocks do you recomend?ill try the rlc brackets and probley some shocks.
Old Nov 3, 2006 | 10:07 PM
Bayer-Z28's Avatar
QA1's are adjustable, but not cheap... Injuneer would be able to help more on this than I would.... He's got experience w/ the ADJ shox... Prolly other people too for that matter...
Old Nov 4, 2006 | 10:36 AM
Dave '97 Z28 M6's Avatar
Yep, Relocation Brackets for your LCA's will definitely get rid of wheelhop.
MyfateZ28
Oct 5, 2015 12:36 PM
rocknroler69
Apr 29, 2015 10:24 PM
sseeya
Apr 9, 2015 06:38 AM
Alex Barnes
Jan 24, 2015 10:21 PM
David Dorris
Jan 17, 2015 08:10 PM
