Uneven ride...
Old Nov 30, 2005 | 08:19 PM
mourningyou's Avatar
Uneven ride...
My shocks and springs were pretty worn out, so a couple of weeks ago I did the front shocks and springs on my car. The stockers were replaced with kyb agx and stock replacement springs (napa). Rears were replaced about 6 months prior.
My problem is that the car is still riding unevenly. The right side of the car sits a couple of inches (by my estimation) lower than the left side. While sitting in the driver's seat, you can tell that the right side is lower, and the car appears lower on the right when you look at it from the outside. The rear end is also lower on the right side (in case you were wondering).
I have no solid measurements of the differences because I don't know where to "officially" measure from. Will fender heights do, or should i be measuring something else under the car?
This is really driving me crazy. Will I be able to fix the unevenness with some spring spacers? Did I install something wrong or not adjust some adjustable parts correctly? If there is no easy solution, will ride height adjustable coil overs fix it? ($$$$$ )
I had planned on getting subframe connectors in the following months, will the uneven ride interfere with their installation?
Any advice on my many questions is appreciated :P
Old Dec 1, 2005 | 11:22 AM
OBE1 95Z28's Avatar
Re: Uneven ride...
There's a couple of things during the install that you could have done to affect ride height. The tops of both the front and rear springs sit in "isolators". These isolators are specifically shaped for the end coil of the springs to mate to them. If you didn't orient the isolators properly, this could affect ride height.
Old Dec 2, 2005 | 08:34 PM
ny_z28man's Avatar
Re: Uneven ride...
I'm actually having the same problem with my new eibach sportline springs. I put the spring absorbers on top on the right way, with the end seated farthest down in the rubber. And one side of my car still sits stock height and the other side sits bout 2 inches lower. I disconnected the panhard bar because I have an adjustable one coming. Anyone ever get a defective spring from eibach????
Old Dec 6, 2005 | 02:53 PM
NZ12'S's Avatar
Re: Uneven ride...
Also Check To Make Sure All Your Tires Are The Same Heigth. I Got 3 70's And 1 60 Installed By Mistake! Cost Me $300 Worth Of Shocks And Springs And Another Mechanic To Finally Figure Out What The Hell Happen. This Was On My Crown Vic Not The Camaro Btw.
Old Dec 7, 2005 | 09:12 PM
ny_z28man's Avatar
Re: Uneven ride...
I have all of the same tires. I just think I got crap springs from eibach!
Old Dec 7, 2005 | 10:54 PM
Re: Uneven ride...
You disconnected the panhard rod? I hope you don't plan to drive it. The rear end will come out from under the car when turning.
TitoPR221
Jan 29, 2015 08:00 PM
JeffsWorld
Jul 31, 2005 11:27 PM
MrCamZ
9
Aug 5, 2004 12:02 AM
GatotsuZeroshiki
Sep 11, 2003 07:07 PM
RobK
Apr 8, 2003 02:45 AM
