Sub-frame connector install ~missing bolt or not?
Old Mar 27, 2008 | 08:03 PM
Joe Bellman's Avatar
Question Sub-frame connector install ~missing bolt or not?
I just received a set of BMR tubular sub-frame connectors from Thunder Racing and was reading through the install directions (see here: http://www.bmrfabrication.com/instructions/sfc001.htm )
It says "Using the provided hardware, slide bolts through subframe connector, subframe, and control arm and install nut finger tight.
I did not receive any hardware. Do I need a longer bolt to do this install and anybody what size? Thank you
Old Mar 28, 2008 | 08:56 AM
From the photos you linked, appears they reused some rusty old bolts.
Old Mar 28, 2008 | 09:26 AM
lastZ's Avatar
BMR should have sent the correct length bolts with the sub frame connectors.....mine came with a pair/
Old Mar 28, 2008 | 10:36 AM
thanks guys.
Richardan15
May 30, 2015 08:36 AM
maybe2fast
Mar 16, 2015 09:45 AM
TitoPR221
Jan 29, 2015 08:00 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
redz_02
Jul 24, 2002 09:42 AM
