Spohn LCA's
Old Dec 11, 2005 | 01:18 PM
PHILLYMU's Avatar
Spohn LCA's
My car is a DD (in spring/summer). I may race it a couple times but it is definately not a track car only. It puts out 440 RWHP and 500rwtq and I am going to do some suspension upgrades. will these LCA's be a good choice as far as noise goes,I want something ill benefit from but I dont want to hear every bump.
thanks
Phil
http://www.neweraperformanceparts.com/default.asp?S=503&A=E&PKV=201|0
Old Dec 11, 2005 | 01:21 PM
2000GTP's Avatar
Re: Spohn LCA's
I have the poly/poly ended ones and they are pretty noisy. It doesn't bother me that much as the exhaust kind of drowns out the squeeky sounds. If you go with the mismatched ends, like poly/rod then I think you are suppose to get less binding and as a result less noise.
Old Dec 11, 2005 | 02:00 PM
ABA383's Avatar
Re: Spohn LCA's
I have the Spohn rod end/rod end LCAs and I love them. They transmit more road noise than my old Hotchkis LCAs, but there is no deflection or binding. I think they definitely helped me do the 1.55 60's...Highly recommend!!!
--Alan
Old Dec 11, 2005 | 10:41 PM
Re: Spohn LCA's
If you've got "squeaks" with the poly ends, they need to be lubed. I ran the Spohn LCA's with poly/poly ends for 5 years and never knew they were there, never heard a squeak. Switched the to rod ends on both ends, and really didn't find themn all that annoying, but then the exhaust drowns out virtually anything.
Old Dec 11, 2005 | 10:44 PM
Compstall's Avatar
Re: Spohn LCA's
Rod ends are typically noisy compared to anything else, but that's up to the user's ears whether or not he/she likes them.
Old Dec 12, 2005 | 09:38 AM
Camarocracy's Avatar
Re: Spohn LCA's
I have the poly ones and lubed them really good. No squeeks so far.
Old Dec 12, 2005 | 12:12 PM
nfa's Avatar
nfa
Re: Spohn LCA's
Some ppl on the roadracing forums have had success with rod end/rubber bushing setups.
Old Dec 13, 2005 | 08:57 PM
PHILLYMU's Avatar
Re: Spohn LCA's
thanks for the info guys
phil
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Dec 30, 2015 09:55 PM
Henson071
Sep 18, 2015 04:01 PM
Boss002
Jul 24, 2015 10:47 AM
