sphon torque arm
Old May 19, 2006 | 04:03 PM
RUFST's Avatar
Question sphon torque arm
getting ready to order one and saw that when putting it on you have to adjust the pinion angle....can anyone tell me what that might be and how hard the arm is to put on and get the angle on the pinion right? Does it come with a gauge?
thanks
Old May 19, 2006 | 04:28 PM
jasonisdn's Avatar
Re: sphon torque arm
thanks
it will have paper work with it on how to adjust it with a angle gauge. take it to a shop with lift ( ake sure it lifts with the tires and not the frame, the rearend should be at the ride height location).
Old May 19, 2006 | 04:37 PM
2000GTP's Avatar
As mentioned above, the torque arm comes with a instruction manual that outlines the pinion angle adjustment. Also, it does come with a very nice pinion angle gauge.
Old May 19, 2006 | 04:57 PM
Good product... the Spohn arm is great, as are the instructions and the included angle finder. Its a little tricky to make sure you understand how to subtract the angle of the pinion shaft and the angle of the drivershaft, but as long as you know the pinion shaft and the DS should form a " \/ " pointing down, you'll be OK. Its a bit of a drag to crawl under the car, but the rear axle can be supported by jackstands to put the components in the correct relationship to measure.
Second item.... please limit posts on LT1/LT4 Engine Tech to engine-related topics. I'll move this to the "Suspension....." forum for you.
Old May 22, 2006 | 05:24 PM
RUFST's Avatar
thanks....yeah i know it has to be at a "V" .....so the car does not have to have the tires supporting the weight, it can be on 4 jack stands or what?
Old May 22, 2006 | 08:28 PM
respectirocz's Avatar
the rear axle has to be loaded, it had to support the weight of the car
if you use jackstands u must position them under the axle
Old May 23, 2006 | 09:28 AM
Seemed clear to me The rear body-to-axle has to be in its normal, loaded postion. Putting the jackstands under the rear axles does that. It doesn't matter what you do at the front of the car..... on jackstands or on the ground. You could also put the rear of the car on ramps. The important thing is the body needs to be at normal ride height over the axle assembly. That means either the wheels on the ground or on ramps, or the rear axle supported by jackstands directly under the axle tubes.
Old May 23, 2006 | 08:10 PM
RUFST's Avatar
thanks guys that cleared it up and i think i can do this now....esp. after looking at your website...Injuneer...and seeing yours! looks good
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
autoxr166
Sep 25, 2015 04:21 PM
Jake Bialke
Sep 24, 2015 11:31 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Bxlt1
Sep 17, 2015 08:31 AM
