sphon torque arm
getting ready to order one and saw that when putting it on you have to adjust the pinion angle....can anyone tell me what that might be and how hard the arm is to put on and get the angle on the pinion right? Does it come with a gauge?
thanks
thanks
Re: sphon torque arm
thanks
thanks
Good product... the Spohn arm is great, as are the instructions and the included angle finder. Its a little tricky to make sure you understand how to subtract the angle of the pinion shaft and the angle of the drivershaft, but as long as you know the pinion shaft and the DS should form a " \/ " pointing down, you'll be OK. Its a bit of a drag to crawl under the car, but the rear axle can be supported by jackstands to put the components in the correct relationship to measure.
Second item.... please limit posts on LT1/LT4 Engine Tech to engine-related topics. I'll move this to the "Suspension....." forum for you.
thanks....yeah i know it has to be at a "V" .....so the car does not have to have the tires supporting the weight, it can be on 4 jack stands or what?
The rear body-to-axle has to be in its normal, loaded postion. Putting the jackstands under the rear axles does that. It doesn't matter what you do at the front of the car..... on jackstands or on the ground. You could also put the rear of the car on ramps. The important thing is the body needs to be at normal ride height over the axle assembly. That means either the wheels on the ground or on ramps, or the rear axle supported by jackstands directly under the axle tubes.
thanks guys that cleared it up and i think i can do this now....esp. after looking at your website...Injuneer...and seeing yours! looks good
autoxr166
Sep 25, 2015 04:21 PM
