SFCs installed/ 80mph+ major vibration
Old Apr 1, 2007 | 12:06 PM
krazykorean35's Avatar
just had some tubular weld in SFCs installed and now at higher speeds 80mph+ there is a lot more vibration throughout the whole car. i can watch the passenger side seat shake from the vibration ...is this normal or should i do something to adjust this? any info would be great!!
Old Apr 1, 2007 | 11:29 PM
When they welded up the SFC's, was the car on a perfectly level surface, with all four wheels fully loaded with their normal weight?
Old Apr 2, 2007 | 12:58 AM
yeh...4 post drive on lift..
Old Apr 7, 2007 | 01:05 AM
gearhead3's Avatar
Bay Area
Hey, Where are you in the Bay Area?
Old Apr 10, 2007 | 11:46 AM
GreenDemon's Avatar
It's possible that the SFCs are allowing more vibration inside the car. You might want to check balance/condition of your tires & rims or see if anything else might be causing it. As an example, before I got new tires and SFCs the seat would shake. New tires took care of the problem, and the BMR boxed SFCs don't cause any extra vibration at all (firmer, but I actually like how that feels compared to chassis/body flex).
Old Apr 13, 2007 | 12:09 PM
marin country...that makes sense. alignment is prob off from hittin donuts.
Old Apr 14, 2007 | 06:54 PM
Z95m6's Avatar
Probably didn't tighten your LCA's up enough.
ImNraged
Aug 19, 2018 08:02 PM
David Dempsey
Mar 12, 2016 12:42 AM
autoxr166
Sep 25, 2015 04:21 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
