Rear Brakes?
Old Feb 5, 2008 | 12:01 PM
GreenGator's Avatar
Rear Brakes?
I have to replace my rear brakes at some point...
I was thinking of replacing the stock rears with a set of "Baer" (to match my front brakes) cross drilled/slotted brakes...
If i remember correctly the rear brakes only do about 10-15% of the braking of the car. So would i notice much of a difference with upgraded brakes or would it pretty much be for looks?
Oh, and its for a 96Z
Old Feb 5, 2008 | 12:19 PM
ssbowtie1's Avatar
Is this a track car? Regardless, I don't think you'll notice a big difference. There's a separate forum for these where you might get better answers btw.
Old Feb 5, 2008 | 12:31 PM
GreenGator's Avatar
Oh Thanks. Sorry for the wrong section post!
Old Feb 5, 2008 | 02:59 PM
That Camaro Guy's Avatar
I'd say put a set of slotted rotors and a set of hawk pads on the back. That would cost you around 200 bucks and give a bump in stopping. The rear brakes don't do as much as the front but slotted rotors are less likely to lock up. I did the LS1 conversion on my front with powerslot rotors/hawk pads. I was so impressed with the safty factor that I got the same rotors/pads for the back. No point in going fast if you can't stop IMO.
-Pete-
Old Feb 6, 2008 | 10:35 AM
2000GTP's Avatar
You won't notice a drastic difference, if you did it, it would be more or less cosmetic related.
Old Feb 6, 2008 | 07:52 PM
Greed4Speed's Avatar
Are your fronts stock size or larger? If larger, a cheaper alternative would be to go with some LS1 rotors that match the Baer pattern.
CGM2010CAMARO
Apr 7, 2015 07:44 PM
Jlo
Apr 3, 2015 10:32 AM
Jazsun
Dec 29, 2014 12:14 PM
trefidy
Jul 26, 2002 03:40 PM
