Rack & Pinion Help.
On my 1997 Camaro Z28 I have no power steering all of a sudden.
How can I tell if it's the Rack & Pinion or the pump?
I pulled the lid off the reservoir and there was presser there so I don't think it's the pump.
But I want to be sure before I buy a Rack & Pinion for $150 +.
Thanks for any help.
I jacked up the car today and while it was on jack stands the power steering worked but it does not work when the car is on the ground.
So I guess the pump is bad.
The pump must be bypassing.
I will replace the pump since it's warranty at auto zone and see what happens if it still does not work then I will know that its the rack and pinion.
I would rather take the pump off then the rack and pinion.
surreybrad
Sep 29, 2015 09:00 PM
