Questions on torque arm/relocator
Old Oct 10, 2009 | 11:29 PM
onefastmx5's Avatar
Just put on bolt in UMI SFC's (car feels way better/quieter), UMI non-adj lower control arms (rear), UMI non-adj panhard rod, and have an s60 rear with chromoly driveshaft on order. For now I'm going to run the stock torque arm, but maybe for christmas I was thinking about upgrading. I'm looking at the UMI adj vs non-adj torque arm and definatly will get the relocation kit. Do I need the adjustable one? Car is a daily driver for now, but will be a drag racer down the road. Car is stock height, and I will NEVER lower the car.
Thanks,
James
Old Oct 11, 2009 | 10:30 AM
You need an adjustable torque arm to set the pinion angle. Higher HP requires an increased negative angle. Its not limited to lowering the car.
The S60 may also have a slightly higher pinion centerline, referenced to the axle centerline, which would require an adjustment as well.
I can't see investing all that money in a drivetrain, then poor-boying it with a non-adjustable torque arm.
Old Oct 11, 2009 | 12:24 PM
onefastmx5's Avatar
Not trying to poor-boy it, just didn't know if I need adj or not. Car will have 500rwhp down the road and see alot of dragstrip. To me it looks like the adjustment point is a "weak spot" and could possibly snap.
The more adjustments on the car, the more complicated it is to setup. Therefore I want to upgrade for my application, but not over-do anything like I see some people do.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
canbaufo
May 5, 2015 03:43 PM
Jason Short
Jan 19, 2015 06:34 PM
RedLineRev
Jan 23, 2003 03:51 PM
