QA1 shocks with drag launch spring set?
Old Jul 13, 2005 | 07:20 AM
mac_z_28's Avatar
Question QA1 shocks with drag launch spring set?
I just purchased Eibach Drag launch spring set. front and back springs. I once heard on camaroz28.com a while ago that the front eibach drag springs do not fit with the front QA1 shocks. ??? is this true? if so why? and if so what shocks do i need to upgrade to? I want the best.
Old Jul 15, 2005 | 10:22 PM
IrocSS85's Avatar
Re: QA1 shocks with drag launch spring set?
I beleive they will work, but you have to buy a custom bottom cup to use stock type springs. or, you can just sell those springs and get the drag springs from HAL that were made for them. I think they're like 275lb sprimgs if im not mistaken. go here
http://www.bmrfabrication.com/F-body....htm#qa1shocks
as Ive just found out, get a GOOD spanner wrench to make adj.s with. the cheap little one I got is horrible.
chris
Old Jul 15, 2005 | 11:26 PM
The seats on the QA1 shocks are a smaller diameter than the stock (or Eibach) springs, so the spring won't sit on the seat. The QA1 drag springs are a smaller diameter at the bottom, to sit on the smaller seat.
You can modify the stock spring seat yourself. Shoebox has one method and some pics. I have an drawing of another method, and also a link to Shoebox's pic. The main difference was he cut his with a saw, and I had mine chocked in a lathe and cut down.
http://members.aol.com/InjuneerZZ/images/sprgseat.gif
stock seat on stock shock:
http://members.aol.com/InjuneerZZ/im...otos/shk04.jpg
modified seat on QA1 shock (by Shoebox)
http://members.aol.com/InjuneerZZ/im...otos/shk06.jpg
Assembled shock/spring:
http://members.aol.com/InjuneerZZ/im...otos/shk01.jpg
RUENUF
May 25, 2016 08:10 PM
siguy
Nov 27, 2014 10:07 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Victory Racing
Apr 19, 2010 06:08 PM
