Qa1 generation F coilover adjust ride height
What was the easiest way to crank up the adjustable shocks. My ride height is way off and the more I crank eventually the spring will keep on compressiing and it will be hard to continue raiseing the shock.
Help needed, what do you all do?
Re: Qa1 generation F coilover adjust ride height
I coated the flat washer, both sides, located under the spring with antiseize grease. This eliminates the binding. Some people have purchased a thrust bearing and located in this same spot. The grease worked great for me.
