panhard rod problem
Old Sep 13, 2010 | 08:42 PM
eric 94z28's Avatar
panhard rod problem
I was putting in the panhard bar and to put in the bolts I had to tap with hammer which I thought was normal, but I came to find out when I went to the other side the bolt wont even go in so I'm guessing that I put the bar in backwards if anyone has any suggestions how to get the bolt back out I have in there that would be wonderful!!! The bolt I have in is on the driver side where the bar is bolted to the rear end.
Thanks!!!!
Old Sep 13, 2010 | 09:14 PM
moparman's Avatar
You could try driving it out with something.
Old Sep 13, 2010 | 09:16 PM
eric 94z28's Avatar
that was my thought but theres really no room there to get a good swing....know if i solder a slide hammer to the head of the bolt would that solder break off....dont have access to a welder....
Old Sep 13, 2010 | 09:40 PM
95TA04GOAT's Avatar
You can't line them up because the axle has shifted. You need to find a way to move the axle relative to the body. A come along will work hooked into something sturdy on the axle and on the body. You'll want to pull in about the same angle as the panhard rod.
Old Sep 13, 2010 | 10:27 PM
henryz28's Avatar
Jack the car up and put the jack stands on the body. This should allow the rear to hang and move enough to line up the bolts. Also I think the bolts only go in one way, remove the bar and make sure the bolts go through the bracket that the bar bolts to.
Old Sep 14, 2010 | 05:26 AM
Wrong forum - this is "LT1 Based Engine Tech". Moving to "Suspension, Chassis......"
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
QuickSilver02
Apr 7, 2015 11:12 AM
silver97Z
Sep 11, 2002 03:17 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
