v6 to z28 suspention?
Old Sep 14, 2010 | 04:49 PM
flip617's Avatar
so i need to get new suspension on my 1995 v6, i am working on doing a swap to the lt1 but that cost money so itll take some time ha. Can i just up grade my suspension to the z28's? or would i have to make changes for it to work?
Old Sep 15, 2010 | 08:44 AM
pgerst's Avatar
Not sure what you mean by new -- new as in worn out ball joints/bushings replaced or want it to handle better? Went through the 1995 manual and there do not appear to be any major differences between the v6 and v8, you just have different springs, shocks, maybe bushings, anti-roll bar diameters, possibly rear drum brakes?
Assuming you want to upgrade, where the Z28 and V6 will be different: Here is a good summary on spring specs: http://www.angelfire.com/my/fastcar/suspension.html Lots of aftermarket shocks, of varying quality, tokico, kyb, bilstein, koni, all sorts of posts on shocks if you search. There are also differences in bushing hardness (1LE being the hardest factory; aftermarket poly harder still).
PS: Another thing you should consider is the 98+ brake upgrade for the fronts and possibly discs for the rear. The brakes are my personal favorite suspension mod; the 98+ brakes are substantially better then the 95 brakes (aluminum versus cast iron, larger diameter rotor, larger pad size).
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Renegade Toker
Jan 23, 2015 10:27 PM
NewsBot
Jan 11, 2015 06:10 PM
Jan 5, 2015 07:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
