Nebie with question about...
Old Feb 18, 2006 | 06:09 AM
95cherryconv's Avatar
Hello all, im on my second camaro now, 96 z28 ttop 6-spd, and now a 95 z28 conv. automatic. My question is on the 95, when driving along the rear end of the car feels out of control like the sway bar is missing. Can anyone give me advice in what can cause the swaying side to side. Thank you in advance.
Old Feb 18, 2006 | 07:48 AM
Re: Nebie with question about...
Side-to-side motion over the rear axle is controlled by the panhard rod. Possibly its loose, the bushings are bad, or the mounting arm is damaged.
Old Feb 18, 2006 | 01:25 PM
Greed4Speed's Avatar
Mine did this for a while. Felt like it wanted to fishtail. A LCA bolt was loose.
Old Feb 18, 2006 | 07:45 PM
Thanks for the replying, but may i ask what a LCA bolt is?
Old Feb 18, 2006 | 08:07 PM
respectirocz's Avatar
lower control arm bolt, the lower control arm, in reference to the rear suspension keeps the axle from moving front/back relative to the chassis, one bolt holds the control arm to the chassis, one bolt holds it to the axle
Old Feb 19, 2006 | 12:57 AM
Z95m6's Avatar
I'd check the panhard rod. I had the same thing happen to me when my panhard rod bolt backed came out on me.
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
67 Camaro
Sep 14, 2002 01:00 PM
Ude-lose
71
Jul 17, 2002 04:52 PM
