Neat brake question. plug unhooked
Old Dec 2, 2011 | 12:52 PM
Camaro350z28's Avatar
Just noticed under my hood that i had a plug undone and just sitting there. its on top of the brake box. i plugged it in and the BRAKE light stays on. So i just unplugged it again but id like to get it fixed. what sensor is it, is it just a sensor checking fluid or does it have a purpose and i dont have abs right now or something?
Also its a 95 m6 z28
Old Dec 3, 2011 | 12:56 PM
Re: Neat brake question. plug unhooked
That connector is for the switch that detects unbalanced hydraulic pressure between the front and rear braking systems. Could be the result of air in one of the lines, a leak or other related problem. Once that switch turns on, it will sometimes not come "unstuck" when the repairs are made. Take it into an open parking lot, and try a high speed, high pedal pressure stop. If the light still stays on, have the brake systems examined for leaks, need to be bled, etc.
You are correct - your ABS system is not operative. Does the "ABS INOP" light come on when you first turn the key on? Someone may have unplugged the pressure switch connector and removed the ABS INOP bulb to cover up a braking problem before they sold the car.
Old Dec 6, 2011 | 01:08 AM
sob i didnt even think to check this. next time im in it ill look for the ABS INOP light. I planned on upgrading to LS1 brakes i have and i know my rears need some help. ill bleed he whole system first and see if i cant get this problem cured before i do any upgrading
Old Dec 9, 2011 | 05:05 PM
ABS INOP light still works. It flashes on then goes off like normal. Not sure whats up... maybe try to just replace that switch or try resetting it and bleeding all
Old Mar 13, 2013 | 02:06 AM
ive replaced everything. complete front and rear brakes and tried resetting light and its still on. not sure what quite to check now. id like to plug it in but i cant stand the light
Old Mar 13, 2013 | 02:07 AM
i know my thread is old just bumping back up for any more possible ideas
REDNECKISBOSS
Mar 22, 2015 08:31 AM
aj2494
Mar 12, 2015 10:17 PM
captcorvette
Mar 7, 2015 12:37 PM
Jazsun
Dec 29, 2014 12:14 PM
