My new CAMARO! ASR Q?
Old Jan 14, 2006 | 06:12 PM
airforceSS927's Avatar
I'm proud to say that I am the extremely proud owner of a black 2000 M6 SS.
I noticed that once in a while a light comes on that reads: ABS INOP and when that one comes on the ASR is automatically turned off. The only way I can get it back on is to shut the car off. It will then come back on in a few seconds. Can anyone tell me why this is doing this and how to fix it?
Replies would be greatly appreciated. THANK YOU!
Old Jan 14, 2006 | 06:27 PM
myslowcamaro's Avatar
Re: My new CAMARO! ASR Q?
without knowing if the car was tuned im guessing 1 of 2 things. bad sensor, (dont know which one tho) or issue with tuning like i had. asr switch didnt do a thing when it was happening but eventually corrected itself, and do it again til i had it retuned.
Old Jan 14, 2006 | 07:11 PM
would it be the abs sensor?
Old Jan 14, 2006 | 10:44 PM
Problem is your car has four ABS/ASR sensors, one on each wheel. You need to check the harness connector for each sensor, and make sure its clean, dry and firmly connected.
If the ABS INOP light comes on, it is possible for a dealer or someone with a TECH-2 scanner to read the code that will tell you what turned on the light.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
1996LT1Z28
Jan 14, 2015 08:09 AM
CARiD
Jan 14, 2015 04:00 AM
ChrisFrez
Dec 7, 2014 06:01 PM
NewsBot
Dec 3, 2014 12:30 PM
