LS1 Brake conversion - Master cyl too?
Old Sep 3, 2008 | 06:50 PM
Ricardo's Avatar
I did the Ls1 Brake conversion a while ago.
Brake feel was improved greatly over LT1 brakes. No complains there.
However, I have noticed some drag on te front wheels every time I change the front tires at the track and my e.t. has suffered a bit too.
I wonder if the master cylinder should also be replaced when doing the LS1 conversion. They do have different part numbers from GM.
Any suggestions or information gratly apreciated.
RG
Old Sep 11, 2008 | 08:13 AM
Ricardo's Avatar
Anybody know what the difference is between 93-97 and 98-02 Brake Master Cylinders?
Maybe the bore diameter?
They do have different part numbers.
Thanks.
Old Sep 11, 2008 | 05:04 PM
Green96Z's Avatar
The only difference is the internal piston. I'm not sure what the difference is, but maybe they upgraded it for the increased brake sizes for the LS1.
Old Sep 12, 2008 | 12:22 PM
tlillard23's Avatar
piston size doesn't matter too much. Bigger piston makes a shorter travel more touchy brake, smaller piston makes a longer travel, less touchy brake.
or so I remember...
Old Sep 19, 2008 | 07:44 PM
max_ta's Avatar
my TA 95 to 02 front and rear brakes left same master no problems so far 6 months
Old Sep 26, 2008 | 03:47 PM
WestCoast96Z28's Avatar
I've never heard the requirement to change master cylinder with an LS1 swap, and that's a pretty common upgrade. I did my LS1 swap about 5 months ago (along with SS brake lines), but no complaints.
I also flushed my brake fluid during the swap..you might consider that first to see if it improves.
Old Oct 11, 2008 | 08:47 AM
Don 97 SS's Avatar
I did the LS1 brake swap about 8 years ago. No problems here and I did not change the MC. If your front brake pads are dragging on the rotor maybe you should regrease the guide pins.
Old Oct 12, 2008 | 09:09 AM
Ricardo's Avatar
Thanks for all the replies.
My brakes have become better and better with use.
I think they were dragging a bit because the rotors were new, pads also new and I had rebuilt the calipers myself with new piston seals.
No drag on the front wheels and great stopping.
Rod Bender
Nov 7, 2023 02:30 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Rod Bender
May 16, 2015 02:16 PM
R@mpage
Apr 20, 2015 10:02 AM
