lowering car - panhard bar needed?
Old Apr 5, 2006 | 04:08 PM
SpeedDemon02SS's Avatar
going to lower the car. eibach pro-kit. also getting new shocks (bistlein II, unless anyone can tell why i shouldn't). Do i need to get a new panhard bar?
Old Apr 5, 2006 | 04:15 PM
hot white z's Avatar
Re: lowering car - panhard bar needed?
You need at least a single-adjustable panhard rod when you lower your car. If you already have one you're good to go. If not, try UMI, BMR, or ebay (I saw an aluminum PHR and LCA set that made me drool once on ebay). Have fun with the Eibach and Bilstein components, they're excellent.
Old Apr 5, 2006 | 04:31 PM
i just have a stock panhard bar in the SS. im just now starting my suspension mods. will i be ok for a bit? or should i do this all at the same time?
Old Apr 5, 2006 | 05:13 PM
slowpoke310's Avatar
after lowering my car, the rear rubbed on one side severely. got a bmr adj phb and saw the rear shift as i adjusted. i recommend getting the adj phb at time of lowering
Old Apr 6, 2006 | 08:15 AM
is it [phb] a hard install? just 2 bolts, right?
Old Apr 6, 2006 | 08:34 AM
Brandon94Z28's Avatar
I lowered my 94 z with eibachs prokit. I had no probs running a non adjustable panhard bar.
Brandon
Old Apr 6, 2006 | 09:30 AM
OBE1 95Z28's Avatar
The panhard bar connects to the frame on one end and the body on the other. When you lower the car the body will shift (when looking from the back) and can cause the rear axle not to be centered under the body. This can cause tire rubbing. An adjustable PHB allows you to center the body over the axle. It's very easy to install.
hotpart's Avatar
Former Vendor
SpeedDemon02SS
Yes it is a very easy install with only two bolts.
Old Apr 6, 2006 | 09:50 AM
do you just adjust by eye?
i'll just order a hotckis one...going to get a STB anyway, might as well order it all at once.
Old Apr 6, 2006 | 11:15 AM
I'm sure you meant to say it goes from the rear axle assembly on the driver's side to the body on the passenger side.
If you work the geometry, dropping the body 1" will move the body 0.10" to the passenger side, relative to the rear axle assembly. Whether that is a problem depends on how correctly the body was spaced side-to-side over the rear axle when the car was assembled. The objective is to have the body centered over the rear axle when the car is at rest. You can measure from the inside edge of the wheel rim to a fixed point on the chassis. Do this on both sides, and see if the spacing is equal on both sides. If it isn't you need to adjust the length of the panhard bar until the spacing on the drivers side and the passenger side are equal.
Old Apr 6, 2006 | 11:29 AM
when adjusting the PHB. do the wheels have to be off of the ground? (ramps or jack stands)
Old Apr 6, 2006 | 02:40 PM
OBE1 95Z28's Avatar
"I'm sure you meant to say it goes from the rear axle assembly on the driver's side to the body on the passenger side."
Fred, thanks for correcting my error.
Old Apr 6, 2006 | 04:41 PM
TobyZ28's Avatar
It should be with the suspension loaded...
siguy
Nov 27, 2014 10:07 AM
thenewkid
Nov 27, 2014 09:41 AM
USAirman93
Nov 24, 2014 03:37 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
