how to take off wheel studs?
Old Jun 12, 2005 | 02:19 PM
lt1maro's Avatar
Well an unfortunate event happened with my car. While driving on the expressway my wheel decided to come off the car while doing 60 mph. In the act of coming off, it sheared off all of the wheel studs. My question is, how do i take off the sheared studs and replace them?
Old Jun 12, 2005 | 02:26 PM
Scream And Fly's Avatar
Re: how to take off wheel studs?
How in the world did that happen??
Old Jun 12, 2005 | 03:11 PM
lt1maro's Avatar
i dunno, i wasnt driving my car, my friend was. When he called me and told me i was like WTF?
Old Jun 12, 2005 | 04:18 PM
sabre81's Avatar
wow that sucks. You should be able to tap them out. You tap the studs from outer side of hub to the inner side. If they are sheared off, you might have to use your imagination. Maybe tap them out with a bolt that is slightly smaller than the shaft of the wheel stud, and poke them out.
good luck
Old Jun 13, 2005 | 11:31 AM
lt1maro's Avatar
cool, so all i have to do is tap them out?
Old Jun 13, 2005 | 12:11 PM
The studs are pressed in. They can take quite a bit of pounding to break them loose. Technically, you run the risk of damage to the bearings from pounding on it. You're supposed to use a press to get them out. But I think most people just hammer them out. I've done the front on both sides to install longer studs, just hammering them out.
Old Jun 13, 2005 | 02:57 PM
Compstall's Avatar
Use a tapered drift and at least a 1 lb hammer if they're sheared off.
Old Jun 14, 2005 | 12:08 PM
lt1maro's Avatar
thanks for the info guys.
Old Jun 14, 2005 | 10:16 PM
O-taka's Avatar
maybe need new rotors after that
Old Jun 16, 2005 | 10:57 PM
respectirocz's Avatar
the bearings are usually alot stronger than any pounding you will do
they are press fitted, if they are sheared off, then ake off the rtor or drum whatever you have, and i use a 3/8 drive extension, it fits very well and it would shatter or bend if u hit it with a 3lb sledge, and just use a lug nut to put the new ones in
now how a wheel came off while doing 60, your frind has a little explaining to do
if one lug is loose it could cause enough vibration to loosen the others and once they're loose the wheel will jostle back and forth enough to shear the studs but the vibration is soo harsh that any remotely intelligent fool would pull over and inspect the problem
but what do i know
Old Nov 26, 2005 | 10:14 PM
Pabz2k1's Avatar
Same sh*t happened to me just now... I heared this bumpin noise figured needed new tires... Went to Town Fair and the guy goes... "You know you're missin a wheel stud here on the front" I go to look and half the stud is snapped off. I was like oh sh*t... Still trying to figure out how it happened...
HarleyZ28
Oct 5, 2015 06:23 AM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
Catmaigne
Dec 25, 2014 12:16 PM
Ken95Z28
Sep 15, 2002 12:37 AM
