how to make ride smoother with summit springs
my ride on my 94 z28 is very rough, id like it to be a bit smoother as im about to be putting sfc's on this weekend and i heard those will stiffen it up a bit.
im unaware as what brand shocks are on it, the fronts are black and the rear red.... but im assuming they arent correct anyways which shocks would soften it up a bit
or should i be looking more into tires? i have 17's front and 18's rears-the rears what feels more stiff
Re: how to make ride smoother with summit springs
40-aspect ratio on the 18's shouldn't cause unreasonable harshness. But some tires can be worse than others. The 40's are probably 1" larger diameter than stock, if your car left the factory with the Z-rated tire option.
Dec 1, 2014 08:08 AM
