Hal QA1 coilover Good or Not worth it
Old Apr 20, 2006 | 10:28 PM
chadlarson's Avatar
Post Hal QA1 coilover Good or Not worth it
Has anyone used the Hal QA1 coilover set up. What has anyone heard? How much can the ride height be adjusted?
Old Apr 21, 2006 | 07:04 AM
Re: Hal QA1 coilover Good or Not worth it
Do you mean the standard QA1/HAL coil-over shocks for the front, the QA1/HAL coil-over conversion for the rear like Spohn sells, or both?
And what kind of car are you talking about.... year?
Old Dec 10, 2006 | 11:36 PM
Klypto's Avatar
from the dead, but are all qa1 kits coilovers?
i have the 12 way adjustable and dont know if coilovers or not.. they said i could raise the car, but doesnt look like it to me?
cofused?
cory
Old Dec 11, 2006 | 08:38 AM
The QA1's for the 4th Gen are "coil-over" in the front, just like a stock 4th Gen spring/shock coil-over setup. The stock shock has a fixed lower spring seat. The QA1 shock has a threaded body, so the lower spring seat can be moved up and down by adjusting the nut that locates the seat.
The QA1's for the rear are not coil-over and are not adjustable.... no threads on the body. Spohn builds and sells a rear QA1 "coil-over conversion" that allows you to use a QA1 with a threaded barrel and lower spring seat, making the rear ride height adjustable as well.
QA1 front shock compared to stock shock:
Threaded body (Shoebox took this one):
Spohn QA1 rear coil-over conversion:
http://www.spohn.net/productimages/736_1_big.jpg
Old Dec 14, 2006 | 10:55 AM
white97T/A's Avatar
would the rear coil over kit offer any advantage for drag-racing or is it more of a road-race/ auto-x application?
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
