Greaseing Poly bushings...
Old Apr 16, 2005 | 05:00 PM
Bow94z's Avatar
Well i installed Prothane Poly bushings on my front control arms (upper and lower). I greased them very well with the greae suppiled. But now when i am driving on rough roads they are very squeaky. I knew from the start they were squeaky when installing poly bushings. I already got my alignment done and really dont want to pull the Arms out again, but want to grease them.
My dad was telling me they make needles you can buy to inject the grease in them and just use a brush to grease along the outsides of the bushing. Anyone ever hear of this? Hopefully this could quite them down a bit if this method works.
And i should use "teflon grease" ,correct??
Thanks!
Old Apr 17, 2005 | 07:48 PM
OBE1 95Z28's Avatar
Re: Greaseing Poly bushings...
I was told to use synethic grease for poly bushings. Energy Suspension sells a "special" grease for poly bushing; it's like thick vasoline. Some guys also mix antiseize grease into the "mix".
Old Apr 18, 2005 | 12:59 PM
RE AND CHERYL's Avatar
I liberally used the grease my poly bushings came with and have had no squeaking problems at all.
96SilverRam
Nov 20, 2016 11:19 AM
RUENUF
Mar 13, 2016 03:37 PM
30th Anniv Z28
Aug 1, 2015 10:39 AM
2QUIK6
Jul 15, 2015 07:46 PM
Hurin
Dec 13, 2014 07:38 PM
