ES Rear Torque Arm Mount
Old Feb 22, 2006 | 07:24 PM
19z28camaro02's Avatar
Arrow ES Rear Torque Arm Mount
Does anyone know how to replace the Rear Torque Arm Bushing from the clamshell at the tail section of the transmission on an LT1? Please any help will be appreciated
Old Feb 22, 2006 | 10:41 PM
Re: ES Rear Torque Arm Mount
http://64.65.63.61/forums/showthread.php?t=430894
Old Feb 23, 2006 | 01:09 AM
Wckd94Z's Avatar
jack your car up, unbolt the old one, slide it off, slide new one one, bolt new one on. lube it up good so it doesn't squeek like a mother
Old Jul 16, 2006 | 11:42 AM
nodnarb481's Avatar
i dug this up from a while ago using the search (arent you proud of me?) and i was wondering what method of jacking everyone uses for this... do i just jack up the front and put it on jack stands? or should i jack up the rear? this is all i need to know and then i can do it
Old Jul 16, 2006 | 12:28 PM
You can jack either end or both.... how high depends how comfortable you want to be crawling under the car. No matter which end you jack, you need to use jack stands before you get under the car.
Old Jul 16, 2006 | 03:01 PM
nodnarb481's Avatar
so if i were to jack the front and put it on jack stands.. after i take off the bushing is it going to be difficult to get the torque arm back where it needs to be with the rear sitting on the ground?
RUENUF
Mar 13, 2016 03:39 PM
canbaufo
May 5, 2015 03:43 PM
Jason Short
Jan 19, 2015 06:34 PM
87Aerocoupe
Jan 10, 2015 07:27 PM
