Do poly bushings squeak alot ?
Old Aug 1, 2006 | 12:16 AM
94Zman's Avatar
About to replace all the front and rear bushings with ES poly bushings, see a few comments on old posts about alot of sqeaking from these..... ?
Old Aug 1, 2006 | 11:01 AM
Re: Do poly bushings squeak alot ?
If you lube them correctly with the right grease, they will not squeak. I put in the ES Master Set about 8 years ago, and there's still no noises in any of the ones that are still left (several deleted when rod-end components were added).
Old Aug 1, 2006 | 11:30 AM
gas huffer's Avatar
i did my car and i was pleased. it handled better and no noise. es is a high quality kit.
Old Aug 2, 2006 | 01:03 AM
94Zman's Avatar
great, thanks guys
Old Aug 2, 2006 | 09:19 AM
ES includes little tubs of white grease with the Master Set. Make sure you use it all up. You can buy it separately too.
Old Aug 2, 2006 | 09:58 AM
jwade95Z's Avatar
I had a set of poly bushings put on my former 91 Corvette. Handled great, but squeaked alot. About every six weeks I would need to squirt some penetrating Graphite Spray on them. I had a mechanic do the conversion for me on that car, and maybe he didn't used a good enough grease, they supposedly had graphite built in
Old Aug 3, 2006 | 11:33 PM
Red_94Formula's Avatar
I have the ES set in my front control arms. No sqweaks.
Old Sep 25, 2006 | 10:58 PM
94Zman's Avatar
Got all the rear part of the kit in, gives a nice tight feel to the ride, minimal road noise. Will skip the torque arm mount, front end in a few weeks...
Old Sep 27, 2006 | 04:40 AM
KLee's Avatar
Got a Hotchkis TVS in the wife's truck, and the bushings need to be greased every 4 weeks. Might have to do with corrosive salt air in Hawaii, but the handling difference is night and day.
Old Sep 27, 2006 | 08:32 AM
blackztpi's Avatar
klee, is it really necessary to remind us that you live in a place much better than most of us??
Old Sep 27, 2006 | 01:37 PM
2000GTP's Avatar
Agree with Injuneer, when properly lubed, they shouldn't squeek. I got stingy when applying the small packets of grease and didn't use it all. The car groaned and squeeked alot. I bought a tube of poly grease and lubed them very well and haven't had any noise since.
Old Sep 28, 2006 | 05:38 AM
KLee's Avatar
If it makes you feel better, we have the second highest cost of living, and the 48th average wages. Not to mention we have a tax for everything.......Peoples Republik of Hawaii.
Old Nov 5, 2006 | 11:55 PM
94Zman's Avatar
Got the front wnd all done, wow what a difference in tight handling.
Old Nov 8, 2006 | 10:31 AM
BradcTA's Avatar
I did the front and rear sway bar bushings and endlinks and it made a tremendous difference!! The first time I took the car around a sharp curve I thought it was going to tip over! Felt like an SUV. No it stay almost perfectly flat around the curves with no body movement to speak of.
RUENUF
Mar 13, 2016 03:37 PM
Daluchman1974
Sep 11, 2015 06:12 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
realistyc
Jul 28, 2015 07:32 PM
colts0455
Jul 20, 2015 09:52 AM
