Clunks on rough roads.
Old Nov 20, 2015 | 07:48 PM
edman's Avatar
My 1995 Z28 has had 9.5" and 11" front and back wheels with Eibach lowering springs for at least fifteen years now, and without issues. But lately, as I drive over rougher roads, my center console ,along with the chassis below, clunks and thumps as I hit shallow pot holes. I think it could be the torque arm. What could cause this?
Old Nov 20, 2015 | 08:59 PM
Fatdog2's Avatar
Re: Clunks on rough roads.
If your car is an automatic then it could be transmission mount.Some dealers still have them,mine did in santa clarita, ca.It was $26.00.Hope this helps.
Old Nov 21, 2015 | 06:46 AM
JakeRobb's Avatar
Super Moderator
I was thinking trans mount as well. Not just automatic -- the setup is similar for manual cars and the part should be similarly inexpensive.
Old Nov 21, 2015 | 06:47 AM
JakeRobb's Avatar
Super Moderator
Also, subframe connectors help immensely on our cars, especially as they get older.
Old Nov 21, 2015 | 12:51 PM
edman's Avatar
My automatic transmission has about 10k miles on its complete rebuild. I just raised the car and underneath I saw the torque arm bushing looks new, feels hard, and the trans mount might actually be new, so I am at a loss!
Old Nov 21, 2015 | 01:15 PM
Did you try lifting the trans off the cross-member, to see if the mount was cracked? Sometimes you can't see the crack with the trans resting firmly on the mount.
Feb 14, 2015 01:40 PM
Lakebratt
Feb 5, 2015 07:55 PM
edxiel
Jan 24, 2015 07:40 PM
Jan 5, 2015 07:14 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
