Clunk in reverse???
Old Feb 1, 2006 | 08:49 PM
z28chrizz's Avatar
Clunk in reverse???
Every time I put my car in reverse after sitting for a day or two, it clunks from the rear suspension, especially if I crank the wheel in either direction. Any suggestions on the source... the car sees a lot of autocross action but the rear suspension is 39k miles of bone stock except for the SLP panhard bar (which i took out and greased the poly bushings thinking it was them).
Old Feb 2, 2006 | 09:49 AM
OBE1 95Z28's Avatar
Re: Clunk in reverse???
Could be your driveline, check your U-joints or play in your differential pinion gear.
Old Feb 3, 2006 | 04:35 PM
z28chrizz's Avatar
Its not when I initially put it in reverse all the time, sometimes it is when the car is moving at a few miles per hour and the rear is under constant load. Its not in the drivetrain... its definitely a body/suspension clunk. Are there coil isolators in the rear? Could the sway bar if the links or bushing are worn cause a clunk but only in reverse? Its hard to diagnose because I cant make the car do it all the time if it hasnt sat for a while.
I have 2 lifted Jeeps... I know what bad u joints are like ... its not them
RUENUF
Mar 13, 2016 03:37 PM
blac94Z
Nov 4, 2015 01:59 PM
dolfan324
Jul 17, 2015 10:34 PM
Beave2780
Jul 7, 2015 06:36 AM
lifesun
3rd Gen / L98 Engine Tech
Jul 17, 2002 09:12 PM
