Car pulls in rutts hard
Old Nov 30, 2011 | 04:05 PM
Camaro350z28's Avatar
Ive had numerous f-bodies and my 95 i am driving right now is one of the worst at staying controllable on the road. it grabs and pulls in every little rutt on the pavement. what can i do to help this, it has to be something cause my cars have never done this before.
275's 40 17s on all 4 corners
Old Dec 1, 2011 | 05:18 AM
Re: Car pulls in rutts hard
Did all of them have the 275 tires?
Old Dec 1, 2011 | 06:19 AM
Procharged94Lt1's Avatar
My car did that too when I had 275's up front- I dropped to a 245/45r17 and it seemed to help quite a bit.
IMO- a 275 up front is a little overkill for daily driving- even simple things like parking lot maneuvers are easier with the 245's up front. Every time I have gone out and had some spirited driving, the back-end always steps out first, even with the staggered tires.
Also- have your alignment checked. It doesn't take much throw off the handling of a vehicle.
Old Dec 1, 2011 | 04:20 PM
yessir they also had 275s up front. its way it sets an alarm and i know there is an issue cause its far worse. i got it on the rack and my toe is out. fixing that and ill have it in the air and check ball joins, tie rod ends, and bushings
Old Dec 1, 2011 | 04:29 PM
jered's Avatar
Bring your front tire air pressure up and it will help alot or get rid of it.I have to keep mine fronts up to 40 psi.
Old Dec 3, 2011 | 12:50 PM
That would indicate you are riding on the center of the tread, and minimizing the edge contact. The center of the tread is going to wear out faster.
Old Dec 3, 2011 | 07:59 PM
jered's Avatar
yes it should but does it doesn't follow the ruts in the road anymore.I have 17s in 17x8.5 in front and 18x10 in rear so i can't rotate them anyhow.
Old Dec 4, 2011 | 09:13 AM
What size tires do you have on the 17x8.5" front wheels? If they are 275 they are too wide for the wheels. Why not just use a narrower tire, that provides full tread patch contact for maximum traction, and will wear uniformly, extending tire life. Makes no sense to me to intentionally overinflate the front tires, wear them out prematurely, reduce the tread patch and traction.....
I've been running 275's in the front for 16 years and while I am aware that they do "tramline", it's never really been a problem, even with the 315's I added in the back 11 years ago.
http://www.tirerack.com/tires/tirete...&affiliate=TZ6
Red97LT1
9
Dec 17, 2014 06:13 PM
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
CobraEatr
Jul 29, 2002 11:46 AM
