Added lca and relocation brackets now tires getting cut
Old Dec 10, 2020 | 12:44 PM
  #16
sherwinZ28's Avatar
Re: Added lca and relocation brackets now tires getting cut
Do you have the part number for the springs and bump stops you used? I have Koni Yellows and eibach springs and the ride is not comfortable and at times feels dangerous. Want to switch out to either the 1LE setup or SS setup if I can find it. Just changed the tie rod ends (inner/outer) and the sway bar bushings but that didn't affect the ride much at all. I'm thinking I need to switch out the upper/lower front arm bushings but definitely want to swap out the eibachs...do not like. I have a 1996 Z-28, not sure if 2002 SS parts fit on my car.
Old Dec 10, 2020 | 03:42 PM
  #17
Germansheperd's Avatar
I can tell you the 02 SS/WS6 springs fit and work great because I have the on my 94 Z28
Front springs: Moog 60116
Rear springs: Moog CC635
OE GM bump stops: 10164173
Old Dec 11, 2020 | 02:48 PM
  #18
sherwinZ28's Avatar
Not sure if it will affect my car however some of the reviews for the Moog CC635 say it lifts the car up 2 inches?
Amazon Reviews for CC635 Amazon Reviews for CC635
It does say it fits my car however the 60116 says it only fits 2000-2002 Camaro which is odd since I thought the suspension was the same. I was planning on using these springs with a pair of bilsteins I had and leaving the Koni's with the Eibachs as a backup set. I ordered some new bump stops as well, appreciate the help!
Old Dec 12, 2020 | 01:04 AM
  #19
Not sure if it will affect my car however some of the reviews for the Moog CC635 say it lifts the car up 2 inches? Amazon Reviews for CC635
It will lift you sagging springs about an inch and sit exactly like an original 00-02 SS.
If you run the Moog 60116, CC635, and Bilsteins all the way around it will look exactly like this:
Old Dec 13, 2020 | 11:48 AM
  #20
grabbem88's Avatar
the moog did raise but it does settle some
WestCoast96Z28
Aug 14, 2007 04:17 PM
nb 96 z
Oct 12, 2006 06:13 PM
Ben Ramsden
27
Jul 13, 2005 04:28 PM
drewstealth
Jun 9, 2004 08:43 PM
PatriotTA
Aug 19, 2003 07:21 PM
