LCA relocation brackets on un-lowered car?
Old Aug 19, 2003 | 07:38 AM
PatriotTA's Avatar
Will weld-in LCA relocation brackets help my launch if my car has a stock ride height? Or are they more for the guys with lowered cars? Also, If I decide to go with relocation brackets, would I be ok with non-adjustable BMR LCAs (since I can adjust the LCA using the different holes in the bracket)?
Old Aug 19, 2003 | 09:53 AM
My experience says they are great for stock ride height cars. I think mine actually sits close to 1/2" above stock with the Drag Launch springs. Dropping the LCA's down to the lowest hole elminated all wheel hop.
And "adjustable LCA's" are sort of irrelevant... you don't need them. They are really only useful for moving the tires forward and backward in the wheels openings, or for correcting thrust angle problems. The relocation brackets have the holes arranged in an arc, so that raising or lowering them does not alter the axle position in the wheel housing.
Old Aug 19, 2003 | 10:57 AM
PatriotTA's Avatar
Thanks for the great answer.
Old Aug 19, 2003 | 12:22 PM
blkchevyz's Avatar
i have them on my car, and mine also sits about 1/2 higher then stock(because of my 9 inch rear end) and the top hole worked best for me.
Old Aug 19, 2003 | 07:21 PM
10.90streetcar's Avatar
I also am useing relocation brackets on a non lowered car. Because of the 9in rear and the taller tire, my LCA were lower in the front than in the rear. The brackets fixed all that and helped with the hook.
Check it out HERE
thenewkid
Nov 27, 2014 09:41 AM
lbrowne
Nov 13, 2011 04:25 PM
94B&RZ-28
Dec 22, 2008 10:00 AM
PaulN64
Aug 8, 2002 05:39 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
