ABS and break pressure problems
Old Mar 26, 2009 | 03:48 PM
YoungCompton's Avatar
Question ABS and break pressure problems
Fist off my ABS INOP light has been on for like 7 months, my BRAKE light just came on like 2 months ago. but the brakes still worked.
Yesterday i changed my brake pads, rotors, and took off my calipers off to paint them(just front). when i put them back on they had no pressure so i bleed them. when i bleed them with car off it builds and holds pressure but when i trun car on all the pressure goes away. i tried bleeding them with car on and it still didnt hold any pressure on the front brakes.
the rear brakes dont have a drop of brake fluid. when i tried to bleed them none came out i took the bleeder screw out and nothing tried car on and off.
then lastly i seen alot of post on here saying i need to bleed my ABS system where is it located and how do i bleed it?
1994 Z28
Old Mar 26, 2009 | 09:26 PM
If you have an ABS code, it may interfere with bleeding the brakes. You need a Tech-2 or other high-end bi-directional scan tool, to "home" the ABS motors, before you bleed. Hopefully, you are starting at the ABS unit, then working at the calipers.
Old Mar 26, 2009 | 10:29 PM
no, how do i bleed the abs system?
Old Mar 27, 2009 | 04:44 PM
Wims97T/A's Avatar
I have had some issues with that after replacing the tractioncontrol.
On the front of the abs unit are 2 bleederscrews like on your calipers.
The methode i use is unplug the battery,bleed the abs first then the usual methode of bleeding the calipers and after that bleed the abs again.
plug the battery take the car for a litlle spin to get above 20 mph( to adjust some valves in the abs unit) and then back to the garage and bleed the rear brakes again.
Old Mar 28, 2009 | 10:56 AM
where is the abs unit located because i dont see anything with 2 bleeder screws
Old Mar 28, 2009 | 01:45 PM
Wims97T/A's Avatar
Just remove the duckting from the maf sensor to the airbox,then you will find these 2 bleederscrews
Old Mar 28, 2009 | 04:29 PM
The ABS unit is the huge, clucky mass of aluminum that that lines from the master cylinder connect to. In this photo, its at the top/center of the photo:
Old Sep 19, 2009 | 03:39 PM
SS44Camaro's Avatar
is this the way to do it?
Victor Lamb
Aug 26, 2017 02:52 PM
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
armedtrigger
Feb 24, 2015 08:30 PM
squarehead
Jan 15, 2015 07:02 PM
