6 cylinde rebuilder (drum to disc conversion)
Im despirate, and after 4 days of no answer in the drivetrain forum... lwets see if the guru's in here can help.
ok... so I need a fresh new 10bolt.... and I went down to the lockal junk yard... all they had was 1 F-body. luckily they had that atleast. It's a 94 6cilinder, but it has a clean rear, with ABS. Only problem is it's a drum and not disk... so I'm thinking of taking the rear of the 6cylinder I found, and throwing in new gears and differential... takign that disc junk off, and tossing on my disc brakes from my 95 Z28... does anyone see a problem with this? BTW how much does a rear axle with out the tires or brakes weigh?
Re: 6 cylinde rebuilder
PLEASE post on the correct forum.
Helpful Hint - You might want to use more accurate "topic" to get responses. "6 cylinde rebuilder" isn't likely to draw the attention of people who might be able to answer a question about converting from drums to discs.
Did you verify the 6 cyl rear had Posi? Most of them don't.
Re: 6 cylinde rebuilder (drum to disc conversion)
Thanks,
I haven't verified if it was posi or not... would that make a difference if I'm goig to swap out differentials?
The reasdon I want to put on a different 10 is that the one on my car isn't the original either, and after swapping out the components it stell seems to be giving me trouble.
I wouldn't buy the junk yard rear just to install all the components from your rear on it. Wouldn't you just end up with you rear with a dirrerent housing.
The V6 cars almost never had posi. A drum brake car is sure not to.
Re'
Re'
carguyshu
Jan 22, 2017 11:19 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
