4 of 6 Kmember bolts in....am I ok?
Old Mar 29, 2007 | 09:36 AM
  #16
Originally Posted by Gtpguy
Well, I asked if maybe it will start to straighten out some. Like braces on teeth. Then after a little time with flexxing and all, the other 2 holes might line up? It's not even put back together yet.
The "braces" for your case would be a frame machine.
Old Mar 29, 2007 | 09:39 AM
  #17
OBE1 95Z28's Avatar
At a minimum, the braces will being going on his teeth after the accident
Old Mar 29, 2007 | 09:56 AM
  #18
Javier97Z28's Avatar
Moderator
That car needs to be put on a frame rack.
Don't go around driving missing two of the bolts. The kind of stuff people think to do is "ok" around here is mind boggling.
These cars don't "settle" to their kmember, or else hundreds of people wouldn't be able to install NEW aftermarket kmembers with no issues lining up holes.
Think about it.
You're confusing "gut instinct" with "wishful thinking"
Old Mar 29, 2007 | 10:09 AM
  #19
Projectz28's Avatar
Moderator
exactly, it needs to go on a frame jig to be straightened. A new K member is just a band aid anyway. It still wont drive right and you will probably not be able to get alignment in spec with a tweeked subframe.
it wont "settle in". its bent and will be that way forever unless you have it fixed.
Old Mar 29, 2007 | 12:38 PM
  #20
Gtpguy's Avatar
How much does that cost?
Old Mar 29, 2007 | 02:11 PM
  #21
Moderator
Depends on the amount of work the car needs. Frame/body work is an hourly labor thing.
Old Mar 29, 2007 | 08:35 PM
  #22
BlackDog's Avatar
When it comes to your safety and others that drive in your car, You will have to bite the bullet and spend the money to get it corrected or sell the car. Just think if something were to go wrong, you might be in for a big lawsuit and have to live with yourself the rest of your life. Not worth it. Get it fixed.
Old Mar 29, 2007 | 08:43 PM
  #23
mdacton's Avatar
being he said one of the middle bolts wouldn't line up....I don't see the frame being bent....sounds like he needs to loosen everything and try again.
It could be bent but I don't see how the middle bolt would be out and not the outer
Old Mar 29, 2007 | 09:19 PM
  #24
Camaro_Guru16NY's Avatar
Get out the welder lol
Old Mar 30, 2007 | 12:51 AM
  #25
Gtpguy's Avatar
Exactly. It doesn't make sense. Oh well. I put it for sale and have like 15 messages on my phone. We'll see. If I get what I'm asking for, then my problems with it are over and I go back to hunting for my beloved thirdgens.
Victor Lamb
Aug 26, 2017 02:52 PM
BLK1997Z28
May 2, 2015 01:26 PM
maybe2fast
Mar 16, 2015 09:45 AM
ddr698
Jan 9, 2015 10:05 AM
