Hello, I have a question about a 1993 Camaro Z28 ABS system, I plan on deleting the ABS system on the car and adding a Roll Control Solenoid. My thoughts are this, to get a new Purporting valve that GM has used for years on all their cars and trucks, Jegs has them 555-631290 and run new lines for the front brakes putting the roll control inline with the front brakes then after the roll control T off the front brake lines to the LF and RF, Block off one port for the front brake line, then a line off the back off the valve to the rear brake line. question is this, will the Brake Proportion valve work? I know it should but has anyone done this on a Camaro ? Thanks for any Input
