abs delete
Old Mar 6, 2010 | 10:28 PM
2 fast z28's Avatar
abs delete
how it going guys im doing a search on removing the abs control unit on my 94 camaro and im thinking about doing my own kit instead of buying one from smj i think i can handle making my own the question is have it all the parts im going to need and where i put the portion valve front or back brakes and i also want line lock if anyone could help that would be sweet and if you got pics let me see
Old Mar 7, 2010 | 10:17 AM
Line lock goes in the front brake line, proportioning valve goes in the rear brake line.
Old Mar 7, 2010 | 11:29 AM
2 fast z28's Avatar
is it easy to make your own or is it easier to buy the kit and does anyone have pics of their setup
Old Mar 7, 2010 | 06:25 PM
The stock brake line fittings are metric with different threads on different ends of lines, and have a unique GM "bubble" flare. You can use adapters, or make your own by finding all the pieces in a brake shop. Personally, I would opt for the SJM kit. It's got everything you need, and maybe a few things you didn't even know you need.
Old Mar 8, 2010 | 07:01 PM
2 fast z28's Avatar
thanks alot more and more i look into it it looks like i wouldnt even save that much money anyways making my own and the kit probably looks better anyways thanks again
IndyZman
Oct 22, 2015 02:17 PM
TGGodfrey
Aug 17, 2015 08:43 PM
tnmotown
Aug 10, 2015 11:52 PM
realistyc
Jul 28, 2015 07:32 PM
