10bolt disc brakes
Old Sep 5, 2021 | 10:55 PM
KYWes's Avatar
10bolt disc brakes
What other GM cars used the 10 bolt that is in the 1993-1997 f-bodies? I'm needing some rear brake caliper mounts and f-bodies are scarce in the junk yards for those years.
Old Sep 6, 2021 | 12:10 AM
Re: 10bolt disc brakes
Long shot, but did you try the GM part # in a search? Shoebox has the part #:
http://shbox.com/1/rr_disc.jpg
Old Sep 11, 2021 | 04:24 AM
KYWes's Avatar
Thanks Fred, I'll check. For some reason I didn't get a notification of your reply to my post. So I'm just seeing this.
I can find aftermarket mounts but they are crazy expensive for what they are.
Old Sep 11, 2021 | 04:59 AM
KYWes's Avatar
Using the suggestion by Injuneer and the part numbers from Shoebox's site it looks like the rear brake caliper mount for a 1993-1997 Camaro or Firebird is only used on those models. Further all GM parts houses show it's discontinued. Strange Engineering provides new mounts on their 12 bolt for the F-body, that fit stock brakes. Monday I'll see if they sell them separately. I may be doing a junk yard trip to pull some axles.
Old Sep 11, 2021 | 08:44 AM
Hawks Motorsports has a salvage yard with 4th Gens. Might be worth a call.
https://www.hawksmotorsports.com/sal.../93-97-camaro/
Jonas
Mar 6, 2006 08:10 PM
damien8618
Feb 15, 2006 03:30 PM
white96camaro
Parts Wanted
Oct 18, 2005 05:11 PM
'86 350
Jul 30, 2005 10:34 PM
1991l98g92
Sep 16, 2004 03:55 PM
