10bolt disc brakes
10bolt disc brakes
What other GM cars used the 10 bolt that is in the 1993-1997 f-bodies? I'm needing some rear brake caliper mounts and f-bodies are scarce in the junk yards for those years.
Re: 10bolt disc brakes
Long shot, but did you try the GM part # in a search? Shoebox has the part #:
http://shbox.com/1/rr_disc.jpg
Thanks Fred, I'll check. For some reason I didn't get a notification of your reply to my post. So I'm just seeing this.
I can find aftermarket mounts but they are crazy expensive for what they are.
Using the suggestion by Injuneer and the part numbers from Shoebox's site it looks like the rear brake caliper mount for a 1993-1997 Camaro or Firebird is only used on those models. Further all GM parts houses show it's discontinued. Strange Engineering provides new mounts on their 12 bolt for the F-body, that fit stock brakes. Monday I'll see if they sell them separately. I may be doing a junk yard trip to pull some axles.
Hawks Motorsports has a salvage yard with 4th Gens. Might be worth a call.
https://www.hawksmotorsports.com/sal.../93-97-camaro/
damien8618
Feb 15, 2006 03:30 PM
