Coolant leak issues
Coolant leak issues
Hey all-
So, I was losing coolant and losing power steering sporadically at low speeds which I attributed to leaking on the belt/slippage on the ps pulley. I traced the leak(so I thought) to the GM crimp connection on the short 90 degree hose from the water pump to the bleeder valve on the heater hose. I replaced that hose and when I went to fill it with coolant via the spill free funnel, I started to get a steady stream coming out of the bottom of the water pump.
Any ideas here? I really did not think my issue was at the water pump or I would have thought the leak would have been far more pronounced. However, the stream was almost as steady as I was putting coolant in the radiator.
Thoughts?
Thoughts?
Re: Coolant leak issues
Unfortunately, that's what I figured. I cannot for the life of me figure out why it just started leaking from the weep hole AFTER I replaced the heater hose. Then again, I usually filled it from the overflow while this time I filled directly at the radiator and it was a steady stream.
Any ideas for protecting the opti during removal?
Also, I noticed on Rock Auto that there are 2 different AC Delco water pumps. One is $97 and the other is $220. What's the difference?
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
