MAF for 94 z28
Old Nov 3, 2014 | 05:44 PM
ANGEL Z28's Avatar
MAF for 94 z28
Have anybody use ACD 213-4657? Is it a good replacement part? I have a stock engine, with 3.90posi When does my engines supossed to chage from close to open loop?
Old Nov 3, 2014 | 05:47 PM
ANGEL Z28's Avatar
Re: MAF for 94 z28
When does the engine suppose to change from open loop to close loop? sorry i am kinda newbie.
Old Nov 3, 2014 | 06:53 PM
Re: MAF for 94 z28
From startup, three conditions need to be met for transition to closed loop:
1 - O2 sensors heat up to operating temperature (~600°F), and become active.
2 - Coolant reaches required minimum temperature, usually about 140°F, but can be higher or lower.
3 - Timer in PCM times out, usually 206 seconds.
Old Nov 3, 2014 | 11:13 PM
ANGEL Z28's Avatar
Re: MAF for 94 z28
Thank you!!!! What about the maf? Is it a good option for a stock engine?
Sent from my Desire HD using Tapatalk 2
Old Nov 5, 2014 | 12:02 PM
Re: MAF for 94 z28
Shoebox has the part numbers on his website. That does not appear to match any of them.
1993-1997 F-Body Part Number Collection
Old Nov 5, 2014 | 02:03 PM
Re: MAF for 94 z28
At the AC-Delco website, 213-4657 appears to be the current stock MAF number. It was joined some years ago with the LS1 MAF.
With numbers changing all the time, it is not really possible for me to keep my list super current, but I try to update it as changes are brought up..
Old Nov 5, 2014 | 02:39 PM
Re: MAF for 94 z28
Sure looks a lot different.
Dec 31, 2014 02:21 PM
pete53
Dec 9, 2014 07:31 AM
formula218
Dec 2, 2014 04:27 PM
RedLineRev
Jan 23, 2003 03:51 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
