MAF for 94 z28
Re: MAF for 94 z28
From startup, three conditions need to be met for transition to closed loop:
1 - O2 sensors heat up to operating temperature (~600°F), and become active.
2 - Coolant reaches required minimum temperature, usually about 140°F, but can be higher or lower.
3 - Timer in PCM times out, usually 206 seconds.
Re: MAF for 94 z28
Shoebox has the part numbers on his website. That does not appear to match any of them.
1993-1997 F-Body Part Number Collection
Re: MAF for 94 z28
At the AC-Delco website, 213-4657 appears to be the current stock MAF number. It was joined some years ago with the LS1 MAF.
With numbers changing all the time, it is not really possible for me to keep my list super current, but I try to update it as changes are brought up..
formula218
Dec 2, 2014 04:27 PM
