97 camaro lt1 problems
The first problem i am having is starting the car on a cold star the car cranks up great drives great but whdn engine warms up and a cut car off while out and about no problems but when i go to start car again while engine warm its acting like a weak battery when cranking but battery is brand new any ideas? Thanks
Re: 97 camaro lt1 problems
The "Advanced Tech" forum is not very active, and it's not for routine engine problems. As a result, there is a warning "sticked" at the top of the forum indicating "DO NOT POST HERE", and another indicating "what this forum is for".
This is not an advanced tech problem, so it's being moved to "LT1 Bsed Engine Tech".
To get help, you need to provide additional basic info about your car including trans and any major mods.
Common problem that causes shutdown when the engine warms up is heat soak of the ICM.
Have you scanned it for codes?
When you go to start it and it cranks slowly, what does the dash volt meter indicate, in volts?
1LEThumper
Jul 14, 2003 12:45 PM
Chrisdude
Jul 24, 2002 02:25 PM
